Shane G
- Feb 12, 2002
Ryan;
I was experimenting with the settings on my Denon AVR3300 last night, the mainspeakers definitly stay as large in the direct mode. So, I changed the settings to large in the stereo mode as well. You should probably leave yours as large, but nothing is stopping you from experimenting.
I've found the sound preferable with the large setting, which would explain why it sounded better to me in the Direct mode.
I would suggest you also experiment with your sub & reciever, by switching it between "sub-only" and "sub & mains" then experimenting with your subs built-in amplifier volume control, phase control and x-over frequency control (I have my x-over set to it lowest possible setting about 60hz). I just run my sub amp hot (a little over 1/2) and use the subwoofer level control on the receiver to adjust the volume. I've read that this configuration will allow for dynamic peaks in soundtracks better, by utilizing more of the subs available power, and by relieving some of the strain off the reciever outputs, so they don't max-out and distort the signal with bass heavy scenes.
Let me know how things turn out, these are a few options you should experiment with, before you retire your sub. These systems are quite complicated now a days, and there is quite a bit of adjustability to suit your tastes/room etc. The best thing is it doesn't cost anything to try all the options, and find out what works best for you.
