Subwoofer? How many watts?
Discussion in 'Speakers & Subwoofers' started by Ben_Ly, Jul 14, 2003.
  1. Ben_Ly
    Ben_Ly Agent
    Jun 25, 2003
    48
    How many watts do I need in a medium sized room. I'd like you to really be able to feel the bass when it hits. Mostly for Movies.
  2. Jeffrey Forner
    Jeffrey Forner Screenwriter
    Jun 19, 1999
    1,117
    Ben;
    I'll let the experts go into greater detail, but I will say that the right subwoofer depends on just more than wattage. The design of the enclosure, the quality of the woofer, as well as the acoustics of the room itself can affect how a sub sounds in any size room.
    Let's get a bit more specific here. What are the dimensions of your medium-sized room? What's your budget?
  3. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    It will also be helpful if you let us know your listening preferences. For example, I am not concerned with listening at reference levels myself, but others want to listen at above reference levels.
  4. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Watts are meaningless without context. What one sub can do with 32 watts, another will require several kilowatts to do.
  5. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
