subwoofer help!!!! (1 Viewer)
bluedev1
mike
What is the name of the input for the subwoofer and is there any way to have my old sub work with this? My old one had a positive and negative wire like the red and black speaker inputs. Any good subs for under out there under $300?
SethH
What you currently have is an unpowered subwoofer. You could hook it up to that receiver by running the speaker cables for the front L/R speakers into the sub and then out from the sub to the speakers.
With that said, you would likely see better performance all around from a powered sub. In the
Robert_J
Mississippi
Good is relative. What size room do you have and what are your goals for the sub and rest of the sound system?
-Robert
babarrun
