subwoofer help!! (1 Viewer)
shitik
shitik
hi people this is my first post...i have a Yamaha RX-V520 and polyway PL-8A speakers....can someone please suggest me to a good sub woofer for my home theater....i don't have rear speakers as of now...will buy them later...but im keen on a sub woofer...please suggest me a good model....thanks in advance
Alex at SVS
Alex Donkle
Hey, welcome to the forums. A couple questions just to help you get the best recommendations.
Do you have a budget in mind?
How loud do you like to listen (moderate, moderate-loud, loud, very loud)
How large is your room? And are their any large openings in it to other parts of the house?
shitik
shitik
reviving this after 12 years :P
Hey
i have a YAMAHA RX-V520. yeah its like super old :p. (waiting for the new hdmi 2.1 receivers to update).
i think my room size is about 10x13
i only have front tower speakers as of now. some brand called polyway (MADE IN USA Apparently)
the above setup of mine is i think atleast 12 years old i guess.
i was looking at a few sub-woofers. budget about 20-30k
Polk Audio - PSW10
Polk Audio - HTS10
Yamaha NS-SW300
out of budget
Q acoustic qb12
will buy center and rear speakers later :P
what do you experts suggest among these subs? or apart from these?
below are the amp and speaker specs
Amp : Yamaha RX-V520
Minimum RMS Output Power per Channel
MAIN, 1kHz, 0.07% THD, 8 ohms - 100W + 100W
CENTER, 1kHz, 0.07% THD, 8 ohms - 100W
REAR, 1kHz, 0.07% THD, 8 ohms - 100W + 100W
Dynamic Power per Channel
MAIN, 8/6/4/2 ohms.....105/125/145/165W
Front Speakers:
Brand: Polyway PL-8A (never heard of it)
Specs:
Frequency Response: 30hz - 22000hz
Sensitivity: 94dB
Impedance: 8 ohm
Recommended 20 - 150 w
Crossover - 24dB
shitik
shitik
have these subs in mind
Yamaha NS-SW300
Polk HTS 10
Elac Debut S10
Q acoustics qb12
Klipsch RS-100SW
Klipsch RS-120SW
also was considering BIC America F12
my room size is about 12x14 (168 sq feet)
i can accommodate a woofer of 14inch width
JoeyT66
