Subwoofer for JBL NSP1 II
Discussion in 'Speakers & Subwoofers' started by kuttaS, Sep 28, 2003.
  1. kuttaS
    kuttaS Stunt Coordinator
    Jul 21, 2003
    111
    can u guys tell me what is a good CHEAP subwoofer for nsp speaker package. the ones i am considering are wm50 and JBL pb10. are there any other good ones and which one is better between these 2
  2. dale^g
    dale^g Stunt Coordinator
    Sep 4, 2003
    60
    i have heard of QC problems with the PB10, just get an extended warranty on whatever you buy...shouldn't be too much considering the amount you'll spend on the sub.
  3. Greg-ST
    Greg-ST Stunt Coordinator
    Jan 27, 2003
    193
    Nearly any sub should match well with that speaker package. If you really want a good "CHEAP" subwoofer then I'd look into the Dayton 10" powered sub at PartsExpress.com. I've heard good things about it and it'll likely be my next purchase to replace my 8" sub. I also have the JBL NSP1II speaker package.
