Subwoofer Excursion test signal??
Discussion in 'Speakers & Subwoofers' started by Christopher_Ham, Sep 23, 2003.
  1. Christopher_Ham
    Christopher_Ham Stunt Coordinator
    Sep 18, 2003
    100
    I was checking around Kaaza for HT test signals and found one called "Subwoofer Excursion". Anyone heard of this??
    Please tell me if it is any good.
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    What are you trying to test?
    I'd be weary of downloading things to test your system with. Not to mention that these kinds of things are a no-no on these forums.
  3. Christopher_Ham
    Sep 18, 2003
    100
    I am looking for a good sub test disk that will give me test signals down to 10 hz or so. I would like to know the name of a good DVD or CD I can purchase. I am sorry, I wasn't clear on the no no's. Won't happen again.
  4. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    Stryke.com has there own disk but you'll have to call because most of there website isn't working. If you have a CD burner, you can download the NCH tone generator(for free) and make your own tones and burn them.
    Here's a post on the Klipsch forum with instruction on how to use the program. I didn't need any instructions...it was pretty straight forward.
  5. Jeremy Stockwell
    Jeremy Stockwell Supporting Actor
    Aug 9, 2001
    608
    There are also downloadable test tones available through the Sonotube Project Links at the top of the DIY forum. (The link appears to be down right now, but IIRC, the test tones are near the bottom of that page when it's available.)
    JKS
  6. Anthony_I
    Anthony_I Stunt Coordinator
    Sep 9, 2003
    177
    can someone explain what IIRC means? ive not heard that one yet.
  7. Frank Carter
    Mar 12, 2002
    1,187
    IIRC=If I Recall/Remember Correctly
    Here's a great site I found when I first joined this board.
    www.acronymfinder.com
  8. SkiingNinja
    SkiingNinja Second Unit
    Aug 14, 2001
    311
    If you want to see the max excursion of your woof, place a 9V battery across the driver terminals.
    Do this at your own risk [​IMG]
    Sean
  9. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Sean,
    I thought the best way was to plug it into your 120V wall socket![​IMG]
  10. Jeremy Stockwell
    Aug 9, 2001
    608
    Do THIS at your own risk!
    JKS
  11. quyen_nguyen
    quyen_nguyen Auditioning
    Aug 26, 2003
    8
    Hi Chris,
    "Excursion test" for the subwoofer is testing the linear travel of the woofer or how loud the speaker can play without distortion. People use "excurision test" to test the maximun linear travel of the woofer. Speaker company use this kind of test to test the driver for "rubbing coil, distortion, ticking or rattle".
    -If you have audio oscillator (signal generator). Apply approx 20hz signal (@approx 1RMS), and turn your volume of the subwoofer up (Make sure don't over drive your woofer, otherwise will blow up your subwoofer if you sub doesn't have good compression circuitry)to check the movement of woofer. If you don't signal generator, I can send you 20hz test tone track.
    Good subwoofer, the excursion can reach up to 1.5 inches without any distortion.
  12. Christopher_Ham
    Sep 18, 2003
    100
    Thanks, I appreciate your responses[​IMG]
  13. GrahamJW
    GrahamJW Stunt Coordinator
    Sep 15, 2003
    84
    Christopher:
    Check the sine waves out at this site:
    http://www.sdinfo.com/down/index.html
    They are from the Secrets of Home Theater and High Fidelity Download page. They are in WAV format, so if you have a PC with a burner, you can burn them to CD audio format and play them from your DVD or CD player.
    Cheers..John
