Brian L
- Jul 8, 1998
A couple comments...
1. Paul, I have burned a disc, but have not run any measurements with it. That said, they are not big files. I could probably zip it and e-mail it to you, if you are so inclind. FTR, my TTG software only allows for levels in whole increemnts, so my worst case error from the published corrections would be .5 dB (using the factors that are in the HTF Archive).
2. FWIW, the RABOS test CD establishs the sub level by first playing a tone that it well above the sub range, where you set the overall system volume to -10 dB on the meter (about 84 dB). Then it runs a sub level tone, and you are instructed to also set the sub to -10. Once you have done that, I can assure you that you will think your sub has gone out to lunch. Why is that? Well, thats a good question. Given what has been brought forth here re:Flecher-Munsun and weighting, it makes my wonder is the RABOS kit measures flat, vs. a weighted plot?
BGL
BGL
