corvette
- Dec 31, 2008
- Pascal
I would like to build my own Subwoofer as I read in most of the post that it is worth a saving.
I built speakers before but from drawings and I am not able to calculate the dimension the volume and adjust the bass reflex.
Reading some posts in these forum I can see that some of you seems pretty sharp on what to do on subwoofer.
What kind of Subwoofer should I build for $4-500.
This does not include the price of the box but only the speaker (s, driver , radiator?), the amplifier, and the electronic.
For the 8 other speakers I will have installed HTD HDW-80 (not purchased yet but I heard it is difficult to get more from your bucks) with a 1.2 cuft perfectly sealed enclosure.
could it be possible to have a potentiometer to adjust the filter for the overlap with the other speaker.
BTW the volume of the enclosure is not an issue as it will be under the stair and I have plenty of room overthere.
The volume of the room is 3000 cuft.
Should I go with two Sub to cover more audio spectre
thanks for your help
