Subwoofer dead? Help!
Discussion in 'Speakers & Subwoofers' started by SummyD, Jul 1, 2005.
  1. SummyD
    SummyD Stunt Coordinator
    Mar 18, 2005
    68
    My new Athena as-p6000 seems to have died. [​IMG] Here are the symptoms. Please help!!!
    The led indicator is no longer lit. it is supposed to be red when sub is on and green when it gets LFE signal. All I hear is a humming sound like from the fridge. This seem to have started happening after I pulled out the audio out from my sat receiver while the sub was still on. Any ideas?
  2. Clinton McClure
    Clinton McClure Casual Enthusiast
    Jun 28, 1999
    4,575
    486
    4,110
    Central Arkansas
    Clint
    I am not familiar with the Athena series. Is there a fuse which popped or a pop-up type circuit breaker on the amp which can be reset? Have you tried unplugging the sub's amp for 30 seconds to reset the power supply?
  3. SummyD
    Mar 18, 2005
    68
    That's what I am hoping happened too. I tried changing the power source. So I guess I need to take it back to dealer. Thanks for the response.
  4. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,498
    353
    9,110
    Cees Alons
    Isn't there a fuse on the panel which you can inspect yourself? If it is, and it's molten, simply replace it by a similar fuse.
    Cees
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    If the fuse blew, there still may be a problem, and since it is a brand new sub, I'd probably opt to take it back in for a look or exchange. Feedback like that can cause damage very easily.
  6. SummyD
    Mar 18, 2005
    68
    ok... I took it to a local dealer and found that its maybe just the LED that blew. Since there wasn't any humming at the dealer's, I was able to ensure that the sub was still working. [​IMG] I changed a couple of things (the rca cable, power outlet) and that seems to have stopped the humming. Guess I got off easy....
  7. Cees Alons
    Jul 31, 1997
    19,498
    353
    9,110
    Cees Alons
  8. Clinton McClure
    Jun 28, 1999
    4,575
    486
    4,110
    Central Arkansas
    Clint
    Are you looking into replacing the LED?
  9. SummyD
    Mar 18, 2005
    68
    Not sure if its worth spending 80 bucks (~40 each way) in shipping to the seller. I think I'll use it a little more to make sure nothing else is wrong, and pass if its just the LED.
