subwoofer crossover
Discussion in 'Speakers & Subwoofers' started by chris bruce, Jan 29, 2005.
  1. chris bruce
    chris bruce Stunt Coordinator
    Jun 27, 2004
    103
    I have a home theater. I have 3 subwoofers. I'm not sure what to set the crossover freq. on the subs at. I can go from 60hz to 180hz. I want as much bass as I can get. I want to feel everybass note that their is to feel. I vave all the subs at the 180hz range and I don't know if I shouls turn them down to the 60 hz range. Can somebody please explain what the diffeence whould be. Let me tell you I have 2 subs in the front of the room and 1 sub behind me. Should I set some subs at different freq. or keep them all the same. I would apreciate any input. Thanks a million
  2. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    How capable are you surround speakers? Response range? Also do you have them set to large or small?
  3. chris bruce
    Jun 27, 2004
    103
    I have infinity qps. They go from 80-20000hz. And I have it set to small. Hope this helps
  4. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Set them to small and set your crossover at either 100Hz, 110Hz, or 120Hz. Experiment with these 3 (assuming your receiver has these options) and see which sounds best to you. General rule of thumb is that you set the crossover as low as possible, but that is limited by your other speakers. Also, you don't want to set above 120Hz unless absolutely necessary.
  5. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    I agree. If your receiver has an adjustable x-over set it to 100hz (most common). If is not adjustable it is most likely all ready set to 100hz, in which case you should turn your subs x-over all the way up to avoid double filtration.
    If you use your receivers x-over(if it has one) turn your sub all the way up as well.
    Furthermore, these are best case scenarios for movies. Music would be a different beast all together.
  6. Ron_Yeoh
    Ron_Yeoh Extra
    Mar 10, 2004
    19
    My Pioneer VSX510 tells me to set the crossover to 200Hz if my speakers are small which they are...but you guys are recommending not higher than 100Hz....what should I do? My sub is a 5yr old mirage PS12-180 which is rumbling oddly at times (not affected by crossover setting)
  7. Nathan Stohler
    Nathan Stohler Second Unit
    Jan 17, 2004
    329
    Pioneer's manuals sometimes give misguided advice on setting the crossover.
    If you set the crossover to 200 Hz, you'll have localized bass (i.e., you'll be able to hear where the bass is coming from, which you don't want). Also, your sub may not be capable of going up to 200 Hz, in which case you will be missing some bass.
    You want to set the crossover slightly higher than the lowest frequency your speakers are capable of (e.g. if your speakers are rated for 80 - 20000 Hz, +/- 3 dB, you'll want to set your crossover to 100 Hz or so).
  8. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    Believe it or not, you might actually be getting less bass with all 3, especially with one in the back. The subs will actually cancel each other out. So it would be worth it to try turing 1 or 2 of them off and testing.
    At least see if the sub in the rear has a phase switch. Set it to 180.
