Subwoofer Crossover Question
Discussion in 'Archived Threads 2001-2004' started by Mindain, Dec 2, 2002.
  1. Mindain
    Mindain Extra
    Dec 1, 2002
    17
    I have an older NEC 12" subwoofer that has a turnover switch on it with about four settings. Which would be the right setting to achieve the best sound. I am using an Onkyo TX-SR600 reciever. Also what does the crossover setting in my reciever do? I have it set at 80 currently. I am a bit of a newbie to the home theater world.
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    The x-over in the rec. is sloping off the highs, just like the x-over in the sub. is doing. The sub's x-over therefore isn't necessary - adjust it to it's highest point to "keep it out of the way".
    Also, these are low-pass filters really, not crossovers. Low bass is "passed on" to the speaker.
    Have fun!
  3. Mindain
    Mindain Extra
    Dec 1, 2002
    17
    So would a higher or lower crossover on the reciever produce better sound?
  4. ColinM
    Dec 9, 2001
    2,050
    Experiment. I don't know what you think better sound is. Generally lower = better, since you would be less likely to notice where the sub is in the room.
  5. Mindain
    Mindain Extra
    Dec 1, 2002
    17
