Mike May
- Oct 10, 2001
I recently ran some wiring in a condo that is being built for me. While running the wires for the 3 rear channels I added an extra run directly below the center rear surround for a possible second sub in the future. Now it's a day or two from drywall and the thought occured to me; did I use the wrong wire? I ran 14 ga. speaker wire like the other runs, thinking I would put RCA connectors on this wire to plug into the sub and amp output. Can I do this or do I need to use the shieled wire that you typically see between RCA plugs? Thanks... - Mike
