Subwoofer connection
Discussion in 'Speakers & Subwoofers' started by Alex_Longoria, Feb 3, 2004.
  1. Alex_Longoria
    Alex_Longoria Auditioning
    Aug 30, 2003
    14
    I have an rca pro-sw60p subwoofer is 60 watts, i currently have connected this by the low level input with the rca cable and it's working good but i have a doubt what's the difference between the low level input connection and the hight leven input connection does this make a difference, or it works the same.
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    The high level connection gets it's input from the front left and right speaker channels.
    I rarely find this performs as well as if it is hooked up line level (low level) to the LFE / Sub output.
  3. Alex_Longoria
    Aug 30, 2003
    14
    Thanks John so you're saying it performs better with the low level input conenction thatn the hight level thanks i have that doubt i currently like this subwoofer it doesn't have lot of power but it performs good enought.
    Alex.
