subwoofer choices
Discussion in 'Home Theater Projects' started by Oachalon, Sep 9, 2005.
  1. Oachalon
    Oachalon Stunt Coordinator
    Apr 23, 2002
    195
    Alright here is my dilemma i have 2 choices to choose from that are about the same price. Choice one is a tc sounds 3hp 15inch sub powered by a bash 300watt amp from parts express. Not sure on box yet but will be ported and probably tuned around 19hz. Or my other choice is 2 infinity ps-12 subwoofers. I have a friend that works at circuit city so 2 infinity ps-12s would cost about the same as the tc sounds sub with amp and cost for materials.
    http://www.circuitcity.com/ssm/Infin...oductDetail.do
    That is the infinity subwoofer im talking about and i can get them for a very low price compared to what circuit city charges from a friend that works there.
    Which would you guys choose.
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
  3. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Good question -
    A. Instant gratification, dual sub flexibility. Inferior comapred to a true custom DIY.
    B. Long build process, labor, finish. Satisfaction. Killer potential.
    I choose B.
  4. SteveCallas
    SteveCallas Second Unit
    Dec 23, 2003
    475
    Unless you really don't want to do any work, I don't see the dilemma. The DIY route will give you much better performance.
  5. KeithMoechnig
    KeithMoechnig Stunt Coordinator
    Jun 25, 2005
    123
    B is definately better. It may be work, but you get exactly what you want.
  6. Oachalon
    Apr 23, 2002
    195
    Im not worried about the work, i built a tempest seeing 7.8cubic ft tuned to 15.4hz running off a 250 watt amp in another one of my rooms. I know b route was probably the better route but i was seeing if i could get out the easy way and be satisified which i probably wouldnt with a.
  7. Oachalon
    Apr 23, 2002
    195
    Also how do you guys feel with the tc 3hp driver. The one I was looking at specs are:
    Re: 6.14
    Fs: 24.5
    Qms: 5.64
    Qes: .362
    Qts: .34
    Le: 5.56
    Sd: 72965 mm^2
    Vas: 138 liters
    BL: 24.35
    Mms: 226.56
    RMS: 6.2
    Sensitivity: 89 dB
    I forget xmax i think its 27-28mm
    Do you guys think this is a capable sub for ht.
  8. ThomasW
    Nov 6, 1999
    2,282
    Everyone posting an opinion has already answered that question
  9. Oachalon
    Apr 23, 2002
    195
    Well since we have that issue solved do you guys have any opinions on box sizes and tuning. I want to go ported and i dont really have any size restrictions but dont want to go huge.
