Rex.G
- Feb 8, 2004
I recently moved and realized i never upgraded my subwoofer cable. I have been using the cheezy one that came with the subwoofer. I remember thinking that i needed to replace it when I was hooking it up at first, but never got around to it. So my question is, do i really need to spend money on a cable? I have not noticed any lack of performance. so what do you think?
set up:
Toshiba 40h80 Monitor
Toshiba SD3750 DVD
Pioneer VSX-D409 Receiver 5.1 DD & DTS
Bic Venturi DV52si Mains and surrounds
Bic Venturi DV53CLR Center
Sony SA-WM500 Sub
Peter
set up:
Toshiba SD3750 DVD
Sony SA-WM500 Sub
Peter
