Bill Griffith
- Jan 8, 2002
Is there a specific cable used to connect subs to Recievers or can any RCA style audio cable be used?
What kind of effects would you see, if any, if you did use basic RCA style audio cable instead of subwoofer cable.
Also given 2 powered subs and only one sub-out on the reciever how should these be hooked up if you want to run them both.
Would running the single line out from the reciever through a Y-splitter be any different than running into one sub input and out the output to the other sub input?
