GrahamJW
- Sep 15, 2003
Hi:
Is it normal for subwoofer amplifiers to get really hot during normal operation? I have a Paradigm PW2200 version 2 and I noticed that the amplifier gets very hot. By hot I mean you can barely stand to keep your hand on the amplifier back plate for any length of time. I also noticed that the amplifier stays very warm after it has been off for a while (12 hours or so). I am not really pushing the sub as the gain is set below half.
The PW2200 v2 does have a 400 watt RMS 1500 watt peak amplifier, so I was wondering if this was normal operation for a subwoofer amplifier. I do know that the earlier version of the PW2200 had heat fins on the amplifier while version 2 does not have heat fins.
Cheers..John
Cheers..John
