subsonic filter on mains.... (1 Viewer)
A
Anthony_Gomez
this seems counter intuitive, so maybe someone can clear it up for me.
For ported subs, we need a subsoni filter to prevent driver unloading.
...then how do tons and tons of people manage to run ported booksheves/towers without one (just think back to old pro-logic where the mains always had full range signals)?
ThomasW
Personally I think subsonic filters are a waste unless one is using vinyl as a source.
I have boost dialed in at 15Hz (Symetrix 551 EQ) for my big IB. And I use 20Hz boost for my other subs that are EQed with BFD's
Greg Yeatts
Tony
Thomas big IB would be in a similar situation to a ported box below Fb. In a sealed box the "air spring" created by the sealed box helps keep the cone in control. A ported box unloads below Fb. In an IB, the cone is always unloaded because the enclosure is so large that the air spring principle would not apply.
ThomasW
Tony
I also have the AS-15 sub and a triple PR'ed Stryke cube containing a BP-1503. These have fairly wideband 20Hz boost from Behringer
A
Anthony_Gomez
thanks..pretty much trying to find out if the tumult in 130L with dual 2500g 18PR's really need a subsonic filter.
HobbitGolf
