Subs with a movie switch? (1 Viewer)
Doug Smith
I like to crank up the LFE for movies, but like to keep it on its proper settings for music. This means I have to go to the back of my JBL to adjust the bass. Any subs out ther in around the five hundred dollar range with front switch to take care of this problem?
LanceJ
Why don't you just change the subwoofer level via the receiver's level control? AFAIK most receivers nowadays remember level settings for each individual input (mine does).
John Garcia
NorCal
The Cambridge Soundworks Newton subs (P500 and P1000) have a remote control unit that will allow you to do this easily.
My old Yamaha sub had a remote with memory settings also, so I had one for calibrated ref and "movie". When I got my new sub, I found it was the sub that was lacking and with my new sub I don't find I need to adjust at all after calibration.
Brian L
You beat me to it Lance.
Being a basically lazy SOB when it comes to my HT, being able to do something from my couch with a remote trumps getting off my lazy ass and doing with a switch, 10 out of 10 times.
And if you like, a lot of universal remotes let you dial program macros that could make it a one button push operation. I had a +3 and a -3 macro on my Marantz RC2000....worked great.
BGL
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Why buy another sub? Just get a remote controller for the one you have. Check the info at this link. A little patience waiting for one will get you in business for well under $100.
Wayne A. Pflughaupt
JoeyT66
