Herb Michelli
- Nov 19, 2003
Im new to the forum and I have a wierd question. Can I use a car sub to build a sub for ht? Thanks
You’re baseless annotations are no more then that of an uneducated, badly informed home theater enthusiast. Don’t worry; I was the same way when I ventured into home audio/theater. You would be exceedingly shocked if you seen some of the drivers out there directed in favor of car audio, I wouldn’t qualm to believe the greater part would humiliate a vast majority of the subs directed for home theater. The frequency the driver can play is far more dependent on the enclosure and tuning frequency, saying “car audio subs don’t/aren’t designed to go as low” is not only comical but more significantly unrepresentative. The world’s finest engineered sub is projected for car audio. Everything about it is a marvel. Gather before you discourse, you would be quite shocked at the outcome.Ok, care to enlighten all us idiots? A 12" Dayton Quatro will not play as low as a Dayton 12" DVC assuming both are put in optimal enclosures, sorry. Both cabinets have to be optimal in a comparison otherwise it is not an apples to apples comparison. One driver is designed to play lower. Typical car subs are not designed to play low on their own and use cabin gain to overcome this deficiency. No, not all car subs suck, but most are overrated, and NOT recommendable for home use.
Though, I would love to know about this wonderful sub that you're keeping all to yourself.
A lot of the car audio drivers can put them to shame for less money, that’s the thing. I am not directing my response to internet retailers only, instead the whole audio scene. Better then the AV15 or Tempest for the price? Both are fantastic drivers. Both internet based companies too. All considered I would put an elemental designs 15K in my living room ahead of both those drivers.Those other car audio drivers for a lot less money than the AV15 which can put it to shame in a HT setup.
NAME THEM.
For $165 the AV15 is nearly unbeatable right now. Not only does a E15K not exist right now, but I can assure you that the older ones would not even compare.
Looking at the e15a for $315 he could get TWO AV15's for only $15 dollars more.
...sounds like a SIN person to me...
If so your deliberation is patheticOh, and the W7 line from JL? The wonder sub? LOLOLOL. Thanks, at least I got a laugh after your insult.
