jcube69
- Jan 12, 2009
- james
im over thinking the whole thing or somthing -.-
any ways the curent box i have planed for two 12" 1200 watt pyle subwoofer is 36 inches long 15 high 24 deep...............im confused to weather that comes to 7.5ft cubed of air space or 1.98 cubic feet
anyways i need some help on building a sealed enclosuer for both subs im not sure if i have enough air space nor how much i need because the subs are not recomended for any sized box -.-
sub specs
Blue Injection Molded Cone
Non-Fatiguing Big Rubber Suspension
Blue Chrome-Plated Steel Basket
Bumped Vented Extended Pole Piece
Silver Plated Terminal
Flat Progressive Spider
New Wave-Like Rubber Gasket
Rubber Magnet Boot
2.5'' High Temperature Dual Kapton Voice Coil
Magnet Weight: 2x90 oz
1200 Watt Max Power Handling
Impedance: 4 Ohm (Per Coil)
Fs:23.2, Qms:4.92, Qes:0.84, Qts:0.72, Vas (Cu ft)4.908
SPL: 85dB
Overall Diameter: 12.20''
Mounting Depth: 6.52''
Sold as: Unit
and about how much air sapce is need for a 12 inch sub? iv hear 1.25-2 cubic feet or the equivlent of 1.96-8 feet cubed of volume.....thats whats confusing me -.- my head hurts
sub specs
Rubber Magnet Boot
SPL: 85dB
Sold as: Unit
