sub woofer insulation (1 Viewer)
Devilish21ca
David Sheedy
Hey everyone,
I've a home theater set up in the bedroom (I know; lucky me!). As part of it, I have a Definitive Cube III (10" by 10") on the floor. Now I know that we shouldn't have bare flooring due to sound concerns, but my wife wanted cork flooring, not carpeting, and that's what we have. I've been thinking of cutting a piece of really thick bathroom mat to put under the cube to give it some insulation.
Is this a sufficient solution, or is there something more creative necessary?
David
Martino
Santa Clara, CA
Martin O.
As a bass player, I use a similar product to float my bass amp - I would suspect it would work for a sub as well
The Auralex SubDude(HD) is a 15" x 15" x 2.5" platform wrapped with a cleanable black velour to fit any room setting. Its purpose is to prevent sound from transmitting through your subwoofer to surrounding surfaces.
These are $60.00
http://truesoundcontrol.com/products/SUBDHD.html
They also have an earlier version that is a little cheaper - at $49.95
http://truesoundcontrol.com/products/SUBDUDE.html
Might be a little overkill for your bedroom...but they will work...
Robert_J
Mississippi
If your sub has a resonant free enclosure then the Subdude or anything else is a waste of time and money. Also the type of floor covering does very little with low frequency acoustics.
-Robert
Robert_J
Mississippi
When you are having room rattles, touch your sub cabinet. Is it vibrating? With an SVS it is probably not. They make very sturdy cabinets.
This type of product is the exact opposite of speak spikes that have been around for years. The spikes couple the enclosure to the floor and keep it from rocking on a soft surface like carpet or a SubDude.
I can make my windows, lights, sconces and even door rattle like crazy but it has nothing to do with the enclosure or floor. I have a very sturdy box and a concrete slab. All of my vibration issues are resonant frequency issues with each item. For some things I've added weather stripping (door), felt pads (sconces) and other vibration reducing material.
-Robert
JohnRice
Bounded In a Nutshell
A Mile High
Robert would be correct. The side effect of a good sub. I spent months with foam tape finding and eliminating as many rattles as I could. Light fixtures, air vents, teeth, etc.
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Oh well, I was hoping for a simple solution. And no, the nearly 200 pound SVS does not move. I would really be scared if it did
Guess I'll have to find the rest of the rattles. I eliminated most by replacing some old glass bookshelves. The rest are coming from the 3 doors in the back of the room. Guess I need some foam tape....
Robert_J
Mississippi
When I was playing around with four 15" subs and test tones, I thought my wife was beating on the theater room door. I paused the CD player and opened the door. No one was there. I repeated the test and the same result. My door has a resonant frequency around 14hz. My SPL meter was pegged at 120db but I could hear very little from the actual sub.
-Robert
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Just an update....
I eliminated some of the rattles with foam and other material in the doors. I could not do much about the floor and could not keep the clocks and pictures safe. So this weekend I finally purchased 2 GRAMMAs to put under my SVS PB12 Ultra/2. The difference is amazing. My windows and doors no longer rattle and he floor is no longer part of the movie. The bass also seems tighter.
BTW - the GRAMMA is the same as the SubDude only bigger and without the pretty covering. I'm all about the sound, I don't do pretty. :laugh:
SHS
scott
I might have to check into that for my Ultra. Weekends should not be just to re-attach everything.......
Reddevil_23
