Chris*Size
- Jan 2, 2004
I recently purchased a new receiver (Pioneer VSX-D812K) which instructs me to connect my sub to it at the connector labled "sub pre-out". Three questions for you:
1) Do I need a specific kind of wire? I am using a single audio cable connected to the "mono" input on the sub right now.
2) Did I hook this up correctly as there are other options on the back of the sub for a L&R audio connection it appears? Prior to this set-up I had the sub wired together with my front speakers as I had an old Dolby Pro-Logic receiver with no sub connections.
3) When setting up the receiver there are different frequency settings that I can tinker with to determine when sounds will be sent to the sub. What is optimal? I have Paradigm Phantom fronts, Paradigm 10' sub, and Pardigm Dipole surrounds. I believe the receiver is defaulted to 100hz.
Thanks for all of the help in advance. This is my first post on the forum as I am a brand new member.
Chris
Chris
