Sub Wire?
Discussion in 'Archived Threads 2001-2004' started by BobHaymond, Feb 18, 2002.
  1. BobHaymond
    BobHaymond Stunt Coordinator
    Feb 12, 2002
    52
    I wil be using 12AWG stranded from HomeDepot for my speaker wire. I notice that the cable sellers all have special cables for sub. Can someone tell me what is special about the requirement for a sub? Can I successfully make one myself?[​IMG]
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    There is nothing special about a sub cable other than perhaps it's length. Yes, you can make your own with CATV coax and RCA plugs. Hint: Subs seem sensitive to having a tight plug so make sure the plugs you use fit snuggly.
    There are requirements for:
    - Video Cable : Must be made with 75 ohm coax
    - Coaxial Digital Cable : Must be made with 75 ohm coax
    Audio cables can be made with any of the popular coax impedences 50/75/110 and even 300 ohm.
    Hope this helps.
  3. BobHaymond
    Feb 12, 2002
    52
    It do. BH
    Hey! I did a double take!! Your note helped even more after the sun came up! I was thinking of having "speaker wire" to the sub. But I finally got the idea from your note that with an amplifier in the sub that the input to the sub audio.
    Thanx a bunch. BH
