Sub that competes with SVS?
Discussion in 'Archived Threads 2001-2004' started by Bergan Peters, Jan 8, 2002.
  1. Bergan Peters
    Bergan Peters Stunt Coordinator
    Dec 7, 2001
    145
    Is it possible to build a Sonosub which is comparable to the SVS 16-46? I haven't seen a DIY driver which goes that low.
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  3. David Giesbrecht
    David Giesbrecht Second Unit
    May 28, 2001
    306
    Shiva in a 150 liter encloser tuned to 16 hz I have modeled this design in LSP cad and it looks sweet. I think a shiva actually has a bigger XMAX so it might actually be better than the SVS 16-46.
  4. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    My sonosub will get down there with relative ease...its tuned to 18hz but it would be easy enough to extend that a little deeper if I wanted to give up a little SPL higher up. Either way there's nothing magical about the SVS subs...they are just well designed and well built subs using a decent driver.
  5. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    I'm sure my Tempest Sonosub would easily beat out a single 16-46CS (as would any other Tempest sonosub tuned to 16-18hz). I would think a fairer comparision would be dual 16-46CS subs.
    I don't quite understand the price differences between the SVS models. From my understanding the 16-46, 20-39 and 25-31 are identical except for the height of their tubes and the length of their ports. The cost difference between manufacturing the different port lengths and tube lengths can't be as much as the difference in their selling prices.
  6. Bergan Peters
    Dec 7, 2001
    145
    http://www.blueprintdrivers.com/1803spec.html
    Did some research, feel that is the most powerful driver you can get at any $$ to be powered by ONE 1000 watt Samson amp. Anyone disagree? The issue I have is that it lists it's output at 92db, that would be trumped by a few Subs, is that at a certain level or what? I want bass that is going to shatter shit and make the neighbors heads explode A LA Scanners. I want the cops called on me, and I dont think 92db is going to reach through concrete walls, am I wrong?
  7. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Bergan,
    Several of us have the Blueprint 1803 but just haven't gotten around to building the enclosures yet. I'm probably going with 4-5ft^3 sealed with low end boost to get flat response.
    Jack Gilvey has played with this in a 14ft^3 ported enclosure tuned pretty low (don't remember exactly where but below 20Hz) and it will definitely "break shit." I get 117dB with 18Hz tuning from 17Hz and up anechoic.
    Brian
  8. Jack Gilvey
    Mar 13, 1999
    4,948
    Before you embark on your shit-scattering project, you might want to look into what the specs mean, it will help your design. 92db is the efficiency rating, not its "SPL limit". And the Fs of a driver is not "how low it will play", that's determined by the alignment, the room, and competent execution.
    The 1803 is certainly the best value I can think of in terms of displacement for the dollar, and I'm not aware of a single driver that would significantly outperform it (that's why I bought one). I hesitate to call anything "the most powerful at any price", though, as I don't know everything about all drivers.
  9. Gil D
    Gil D Supporting Actor
    Mar 15, 1999
    577
  10. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    One thing to mention is that these extreme excursion drivers (1803, HE15, etc.) tend to require more power (i.e. greater amp expense) as well as EQ at the higher frequencies (due to an inductance hump). Not raining on anyones parade, just be aware that these are the tradeoffs...
  11. Jack Gilvey
    Mar 13, 1999
    4,948
    Yeah, I point that out whenever possible, Greg. That's what can make, say, a Tempest a better choice in many situations. In order to make something like a Blueprint worth using (to realize its potential, which is prodigious), you've got to work with it. Didn't seem worth getting into the details just yet, though. [​IMG]
