Sub settings
Discussion in 'Archived Threads 2001-2004' started by andy_brehm, Oct 25, 2001.
  1. andy_brehm
    andy_brehm Stunt Coordinator
    Oct 10, 2001
    155
    I was wondering what settings I should use for my sub. I have a DCM 1212 that has a 130 watt amp built in along with a crossover. It connects to my Yammy RX-V1000. I was just wondering what I should have my crossover set at, what gain I should give it, and if there was anything I need to adjust on the receiver to get a good output. Eventually I plan on getting AVIA, and I believe that helps calibrate your speakers, correct?
    When it comes to speaker setting I am clueless. Im not really sure how to adjust the stuff, but if you guys could recommend a setting I could work at it.
    thanks
  2. andy_brehm
    Oct 10, 2001
    155
    For this matter, how do you calibrate all my speakers? I plan on picking up a copy of AVIA in the near future, does that lay it out pretty well so it is easy?
    Thanks!
