Sub/Sat owners - Speaker Wire (1 Viewer)
JosephD
What gauge wire are you using? Is 12 gauge wire overkill? I bought a spool of Monster Cable XPMS (16 gauge?) but I'm thinking I should just buy the bigger stuff. Any thoughts?
BTW my longest run will be about 37 feet.
Thanks - Joe
Jose G
The 16 is fine. I go 14 for all around, including surrounds, but if I were to have already have had 16, I would have used it, and no one would be able to tell the difference if compared to my 14 or even a 12 for that matter. Save the cash if you can, and spend it on dvds or cds- enjoy the music! Take care.
RubyBird
