Chris Ryan
- Apr 14, 1999
Hi:
I have a question regarding sub calibration? I am using a Denon 5800 & have Def Tech. BP2000's and a Infinity Intermezzo 1.2s for subs. How exactly should I have the sub volumes on the subs when trying to calibrate? Half, quarter, etc? Right now the volumes on each sub are way down. On the Denon, the peak level limiter is set to -13 db. Should I even use this? The sub level is set to +5 DB's. I just don't think I am getting all I could be from them. Also, when I use my level meter & VE for sub calibration, the needle never swings. It's always at the far right.
PS. I want the Infinity to do most of the work & my mains are set to Large the rest are small and I am using LFE+Main.
Chris
Chris
