Sub RCAs- do these look good?
Discussion in 'Archived Threads 2001-2004' started by Matt Nevala, Feb 2, 2003.
  1. Matt Nevala
    Matt Nevala Stunt Coordinator
    Dec 12, 2002
    61
  2. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    I have used this brand of interconnects and have worked very well for me.
    You will not need the adapter, just use one channel of the cable. Save your money.
  3. Tim Morton
    Tim Morton Stunt Coordinator
    May 5, 2000
    212
    Do you know they make dedicated mono subwoofer cables?
  4. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    Dedicated MONO sub cables are gonna be pretty expensive. I would consider getting some RCA's used for car audio and then just pull the two cables apart from each other. If the single cable isn't long enough, you can get a connector to attach them. That is what I did and saved a ton of money.
  5. Matt Nevala
    Dec 12, 2002
    61
    so if i do get regualar car audio RCAs and split them, does it matter if i use the right or left cable? i think someone said before to use the red, but im not sure.
    thanks,
    matt
  6. John F. Palacio
    Jan 6, 2002
    575
  7. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    Use the red. This is what the DLS literature says to use. I do use a Y split to the sub but it's not necessary.
  8. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    The color won't matter. The only reason why they are marked is so that from the Head Unit to the AMP you don't cross the Left/Right Signals. Same thing goes with Wire.
  9. MikeCooper
    MikeCooper Extra
    Jan 4, 2003
    16
    This is the cable I'm using:
    http://home.new.rr.com/zaph/audio/audio-cables.html
    Made myself a nice 25 foot length of the stuff, it's great!
    The splitter I'm using since my receiver also has a single RCA output, is an Acoustic Research one I got tossed in when I bought the sub. Oh, and yes, definetely get a splitter.
  10. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    Here's my take on a Y-splitter..
    CLICK
  11. Matt Nevala
    Dec 12, 2002
    61
    thanks Bill,
    i just so happend to find a spliiter thing, but in not sure it is exactly what u guys are talking about. its a small piece that has one male and 2 female and says radio shack. will this work?
    thanks
    matt
  12. Bill Kane
    Feb 5, 2001
    1,359
    Matt,
    you certainly can try a Y-splitter on yr new sub without harm -- a RS version is
  13. Matt Nevala
    Dec 12, 2002
    61
    i see what u mean...but couldnt i hook this connector to the reciever and then i woule have 2 female ends which i could plug regular male RCA cables into?
    matt
  14. Tim Morton
    May 5, 2000
    212
    Your receiver should have a single female LFE output.
  15. Matt Nevala
    Dec 12, 2002
    61
    It Does have a single female output, so thats why i asked if i should use this adaptor to make it two female output.
    then i could use a regular set of R/L RCA cables.
    am i thinking right, or should i just stay one femout output to a one female to two male output into the sub amp?
  16. Jose G
    Aug 18, 2002
    568
    You want a single cable to the receiver (that's male rca to receiver's female out) and on the other end of that cable (which is another male), you want a Y-split (single female to dual males). The male from the cable goes in the female (Hey stop that- there may be children reading!) which converts to two males (now it's getting interesting) which go into your subs dual female ins. This seems all very kinky, but it's innocent- I swear. And it works.
  17. Matt Nevala
    Dec 12, 2002
    61
    HaHa, well that was interesting, but i now understand how the system works.
    thanks everyone,
    matt
  18. Matt Nevala
    Dec 12, 2002
    61
  19. Jose G
    Aug 18, 2002
    568
    [​IMG]
  20. Matt Nevala
    Dec 12, 2002
    61
    cool, ordered yesterday and being shipped today along with the sub being shipped today.[​IMG]
