sub question
Discussion in 'Archived Threads 2001-2004' started by Chris Muc, Nov 28, 2002.
  1. Chris Muc
    Chris Muc Auditioning
    Nov 27, 2002
    I am upgrading my father inlaw's surround system. I got him a Harmon/Kardon AVR320 reciever to upgrade from his Onkio pro-logic unit. His C/V subs are not powered(2X10 in ported box). Should I use the "sub out" from the H/K unit to a remote amp for "LFE" or send left and right from the H/K unit through the subs (built in X-over) then to the speakers. The H/K unit has a feature that will send the "LFE" to the front speakers if you feel they can handel it and you don't have a sub. Any suggestions would be great. I will experiment as well and post my findings.
    Thanks in advance,
    Chris
    ps. Great site lots of info
  2. Hugo
    Hugo Stunt Coordinator
    Nov 21, 2002
    147
    Hi Chris,
    if you mostly like to watch movies, I would defenitely go for the remote amp, but if you use your system for listening to music, I would go for the speakers way. But that's only my opinion, try experimenting and see it for yourself. Hope that helps.
    Hugo
