Greg P
- Jan 7, 2001
I just finished a sealed Blue Print 1503
Amp: Crest LT-1000
Box Material: 1.5 in thick Mdf Box
My problem is on certain low frequency music the woofer or box is making a different sound all of a sudden. Its not like a gradual distortion, its all of a sudden like a smack or odd sound that sounds different from the note and its not listenable when it does this. It is loud when it does this but not as loud as you would think for distortion( If thats what it is) like this. It depends on the music or tones but can happen as early as -15 on my reciever. The amp will not even be moving into the red, so its not the amp clipping. I have 2 brace in my box of .75 Mdf, situated like the Aerial stryke sub by Thomas W. Im thinking it may be box resonance, and I may need to add more bracing. I was think of adding 1x1 in each corner going from the front to the back of the box. What do you guys think, can yo tell me whats going on?
Amp: Crest LT-1000
