Sub Power?
Discussion in 'Archived Threads 2001-2004' started by Jassen M. West, Feb 1, 2002.
  1. Jassen M. West
    Jassen M. West Supporting Actor
    Jun 22, 2000
    526
    110
    Can i leave my 20-39SVS plugged in as long as its in the "Auto" mode? I wasn't sure if thats what that mode is for.
    thanks
    ---jay
  2. gene avallon
    gene avallon Stunt Coordinator
    Jun 13, 2001
    187
    most likely is there a led light on the back it should be light when its playing,and when you shut everything down it should go out in a little while
    gene
  3. Thomas_Berg
    Thomas_Berg Screenwriter
    Feb 28, 2001
    1,422
    Dallas
    Thomas
    i left my 25-31PC on auto 24/7 and never had to worry about it.
  4. JamesMart
    JamesMart Agent
    Jan 23, 2002
    47
    One problem I have with auto mode on my audiosource sub is that some times it takes a lot of bass activity to get it to kick on. Like if I'm watching TV, it will cut on and off. My sub does not have the option of full time on, does the SVS PC have a full time on?
  5. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    The SVs have a full time on.
    James, try turning down the subwoofer volume knob and increasing the receiver's subwoofer *leveler* a bit to compensate. This will push more voltage to the sub(although overall levels stay the same)...which should activate the auto-on feature quicker.
    TV
  6. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    It would be nice if those auto-off things would wait an hour or hour and a half before switching off. That way, they wouldn't be switching on and off during a movie. It seems like the popular amount of time is like 5-10 min., but you're going to have 5 min. or no bass in most movies.
