Sub placement trick (1 Viewer)
Dave Getson
I lent my sub to a friend to experiment with. I went to visit him and it sounds like total crap in his room. We tried placing it in a few different spots and really, it still sounds like crap. I was wondering if the ol' put the sub in the prefered listening spot and crawling around until you find the best bass response would work in a room that's L shaped. The vertical part of the L being the only part used for HT, the couch at the bottom. If it does, I'm going to tell him to try it.
Kevin C Brown
It should. The idea behind that method is to find the opposing location that offers the best combination of output and flat response to your ears.
Make sure all the old standbys are taken care of though too: phase, calibrated levels, BM set correctly in the receiver or pre/pro, etc.
Eddie Horton
The trick should still work. If it still sounds like partial crap, then it's not the trick's fault.....it's that funky L shaped room.
Guy Usher
Put the sub in your listening spot then walk around the room untill you find where it sounds best. Sit it there.
Worked for me several times besides it is easier to crawl around the room than drag the sub all over the room
Kcuster50
