Sub placement in corner, and height off ground questions
Discussion in 'Speakers & Subwoofers' started by Joe Hsu, Aug 26, 2003.
  1. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    So I finally got ahold of the enclosure for my Tempest, and everything is up and running mighty fine...but the thing's a beast (18" sonotube, almost 6' long), so I want to stand it up in the corner. With the ceiling being only a foot away, will that create any problems? And I'll just stick some wood on each corner and elevate it, but should I put the driver or port side facing down...does it matter? And depending on which side I use, is there a minimum height I should make the legs?
    Thanks all...I love the sub and the bass, but the aesthetics certainly leave a little to be desired.
  2. BenSC
    BenSC Stunt Coordinator
    Jun 19, 2003
    190
    If I remember correctly, the Tempest gets its "best liniar dispersion" when mounted downfiring. I remember reading this in the Adire stuff somewhere.
  3. Joe Hsu
    Jul 2, 2001
    812
    Hmmm, thanks Ben. Any other inputs?
