Sub or receiver's crossover
Discussion in 'Beginners, General Questions' started by Ben LG, Jun 7, 2003.
  1. Ben LG
    Ben LG Stunt Coordinator
    Jun 30, 2003
    225
    I read alot of articles and there seems to be a difference of opinion on whether the recievers or sub's crossover should be used. First off, I have a AR sub connected to my Onkyo receiver's LFE preout to the sub using an RCA cable. I actually have a couple of questions so Ill just spit it out [​IMG]
    Should I be using the line in or speaker terminals on the sub if Im concerned about quality?
    If I was to set the crossover on the receiver at 100, should I do the same with the sub or dial it to the min (theres no switch to bypass the sub's crossover)?
    and last, I have Infinity towers and I think they can extend down below 50hz but I cant check the specs cause Infinity's site is down atm so dont know if its accurate. Should I set the crossover at 80 or 100?
  2. Brian Fellmeth
    Jul 30, 2000
    789
  3. Yee-Ming
    Yee-Ming Producer
    Apr 4, 2002
    4,383
    29
    1,610
    "on a little street in Singapore"
    Yee Ming Lim
  4. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    Stick with the line-level connection to your sub.
    If you use the speaker level connection, most subs do not high-pass filter the output to the speakers that are connected to it, or they'll have a fixed frequency high-pass which is usually way too high. It's much too easy to leave a frequency response hole this way.
