Sub On
Discussion in 'Archived Threads 2001-2004' started by AbelM, Jan 3, 2002.
  1. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Is it harmful to leave my sub on all the time, without it in standby? Cuz when I have the option for it to go into standby, sometimes it just shuts off in the middle of songs...and it really sucks. So if I leave it on it stays on, but will that hurt it when I am not using my HT at all?
    Thanx.
  2. WilliamM
    WilliamM Stunt Coordinator
    Dec 29, 2001
    60
    It will not hurt your Sub at all. Just a little extra use of electricity. [​IMG]
  3. Brian Fellmeth
    Jul 30, 2000
    789
    Try turning the sub amp volume knob down and make a compensatory increase on the receiver's sub trim. Should eliminate the problem.
  4. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
  5. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
  6. JerryW
    JerryW Supporting Actor
    Feb 7, 2001
    640
    Yes, that's exactly what he means. Just make sure to lower the volume on the amp to compensate for the increase in LFE level.
    What's happening is your sub is going into sleep mode because it doesn't think there's a signal coming from your receiver. Increasing the LFE level may remedy this.
  7. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Ok, but if this doesn't work, does it hurt my sub or amp to leave it on all the time...???
  8. JerryW
    Feb 7, 2001
    640
    No, it won't hurt your sub or amp. Just might cost you a few more dollars a month in electricity.
  9. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Well it's better than loosing my bass...but I'll try the other suggestions first and see, thanx!
  10. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    I've had my M&K MX700 sub turned on permanently (all the time) for the last 3 years with no problems.
    So I say just leave it turned on, with the auto-on circuitry turned off.
    BruceD
  11. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Bruce:
    Thanx man that's very comforting now [​IMG] I'll keep mine on now without a worry, whew!
