Trevin Chow
- Oct 24, 2003
If you put a sub right next to a couch, is it going to be a problem for the person sitting on that side of the couch? Assume that the sub is properly calibrated.
I'm not sure if your TV is in a corner or not. One other thing is that the subs won't be shielded. If you have a standard tv, you'll need to keep it 3-4 feet away from the TV as a minimum or you will have lots of problems with the magnetic field messing up the screen.John, thanks for teh input. I've just placed an order for the SVS 25-31PCi cylinder and will be putting it behind my TV. All the forums I have posted in, and SVS themselves, say that this placement should have no affect on my TV. So looks like I'm good to go!
