Sub material questions (1 Viewer)
JohnA
I am putting the wraps on finalizing my Tempest plans and am now left with the enclosure materials.
Adire Audio recomends void free birch plywood as first choice, I have seen many people recomend the MDF over the ply. Adding to the confusion is the recomendation to use teh ply for bracing and MDF for teh enclosure.
What does your experience tell about teh benefits and drawbacks of each method?
If you want to see a snapshot of a 3D CAD model of what I am planning, check out this link.
http://members.aol.com/johnariel/box1lowres.bmp
AlohaTiger
