scottAtah
Grip
- Aug 20, 2004
OK, well it's actually only happened twice. But i'm concerned as to why, i've got a couple ideas either volume or too low, which i thinka re the only real options or a combo, but i'm not sure.
the sub in question is a paradigm pw-2200....when listening to music of movie (once each) at louder volumes the sub has made a POP sound, i'm usually quick to turn things down a bit cause that always makes me nervous. The first time on the music, it was a rather low bassline up loud, last time was just watching the third lord of the rings....
whats causing it? what i'm i wrecking?
Sub's internal amp is turned to about 45% or so with it's cutoff freq set to about half (can't remember the range), and the receiver volume panasonic sa-xr50 was turned up to about 30 (counts down)
