Rick Radford
- May 12, 2001
I just noticed that when I crank up the Samson channel level input control to 0db, I get a noticeable hum from the sub. It's barely noticeable at -10db. I can't hear it when source material is being played.. but when nothing is playing, it's quite evident.
This only occurs when the TV is on. I thought it might have to do with the receiver power cord being routed behind the TV.. but changing this did not affect the hum.
I moved the speaker wire (12g Carol) around in an attempt to see if this was the problem.. but the hum persists... no change.
Any ideas?
--RR
Any ideas?
--RR
