Sub hum help
Discussion in 'Speakers' started by Cameron Yee, Nov 11, 2003.
  1. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,680
    648
    Since 2006
    Cameron Yee
    I emailed SVS already and thought I would post the message here for additional input.
    Hello. I have 20-39 PCi and am getting a slight hum from it. It is so slight
    I wonder if I'm just being overly picky, and have let it slide for awhile.
    But the curious part of me would like to at least have an answer, whether
    "that's just the way it is" or something practical.
    I am pretty positive it is not a ground loop problem as I have tried the
    standard test of removing the antenna/satellite cable connections from my
    system. Also since the power cable is two prong I figure that is not the
    issue.
    The hum goes away when I turn the receiver volume all the way down or when
    my DVD player is switching around the disc and apparently is not sending any
    kind of audio signal to the receiver. One thing that affects the volume of
    the hum is the crossover switch on the sub. When I switch it to "Enabled"
    the hum is less noticeable. I am wondering if something is going bad in my
    receiver's crossover circuitry if this is the case.
  2. Tim Ranger
    Tim Ranger Stunt Coordinator
    Oct 22, 2002
    131
    Sounds like the sub is amplifying a hum that comes from somewhere upstream, perhaps the DVD player or the cable from the DVD to the Rec.
  3. Anthony*B
    Anthony*B Stunt Coordinator
    Aug 6, 2003
    205
    my Dayton 10" has a very faint hum that NOTHING has been able to fix so far...i have fortunately been able to block it out...normally i obsess over such things, but this one is so slight i can ignore it...
  4. Cameron Yee
    May 9, 2002
    11,680
    648
    Since 2006
    Cameron Yee
    I have tried other sources besides the DVD player and the the hum is present regardless of source. As I said, the hum is very slight, and have for awhile considered it just a quality of amplification. So perhaps a more pertinent question is if it is realistic to expect dead silence from low to moderate range equipment?
    BTW there is no detectable hum when the sub is disconnected from the system.
  5. jonny h
    jonny h Agent
    Oct 23, 1999
    37
    What kind of receiver do you have?
    Also, did you have this problem on a previous sub?
  6. Cameron Yee
    May 9, 2002
    11,680
    648
    Since 2006
    Cameron Yee
    I have an Onkyo 575x. The sub I had before was a Sony SA-WM40. I believe the hum was also present but I can't say for certain. When I got the SVS I became a little pickier I think.
  7. Steve*W
    Steve*W Agent
    Nov 2, 2003
    35
    I work at an electronic retailer, and had a customer that had the same problem with a sunfire sub. He solved it with a monster power line conditioner. He thought it was most likely being caused by interference with a new (massage)chair that he just bought, but never really found out what it was.
    We also have the same problem with one of the subs at the store (JBL E150P). All I do to fix it is rock it back a bit, and it seems to go away. Bad example, cause I KNOW it's interference on that one, just too lazy to fix it.
  8. Cameron Yee
    May 9, 2002
    11,680
    648
    Since 2006
    Cameron Yee
    I got a Better Cables Silver Serpent cable from SVS and that seems to have solved it. I'll post back if I experience anything different.
