Sub Hum, Cheater Plug Doesn't Help
Discussion in 'Archived Threads 2001-2004' started by Ian_B, Aug 17, 2001.
  1. Ian_B
    Ian_B Auditioning
    Jan 11, 2000
    9
    My twin 16-46CS subs both have a hum whenever they are turned on, I've tried a cheater plug, but it doesn't help. Any other suggestions??
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,241
    20
    1,610
    Try a different subwoofer cable.
    If that doesn't help...a GLE(ground loop eliminator)from RS might work---about $15.
    TV
  3. John Morris
    John Morris Guest
    Plug the amp for the subs into an outlet which is on a different circuit breaker than the rest of your equipment. If the hum goes away, then it is ground loop hum. If not, then you have a different problem, like one with the subwoofer output from your receiver or pre/pro.
    Take Care,
    merc
    DFAST, 5C, DVI, HDCP, SafeAudio, Macrovision and Lewinski!!!
  4. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
    Do you have cable? If so that may be the cause of the hum.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
  6. Ian_B
    Ian_B Auditioning
    Jan 11, 2000
    9
    I've tried going from one cheap cable to another, but I don't have anything that was more then 5$. I do have cable TV, does that have any effect?? Line Level Cables, Speaker Level Cables, refresh my memory on what the differences are. hehe.
  7. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Your CATV coax can often inject a hum into your equipment.
    Turn the system on so that you can hear the hum, then un-screw the CATV coax from your system (TV, VCR, etc). Does the hum go away?
    If so, try this site for a solution:
    http://www.dplay.com/tutorial/cablehum.html
  8. Ian_B
    Ian_B Auditioning
    Jan 11, 2000
    9
    I found the problem, it wasn't cables, I had the ART 351 eq. stacked on top of the samson amp. I was moving it around and I found when I lifted it off of the amp, the hum would go away, and when I set it back down the hum returned. Kinda wierd, but I just moved the ART to another shelf and the hum is gone.
  9. Steve_D
    Steve_D Second Unit
    Nov 28, 1999
    299
    Interesting....my ART 351 also made a hum so I flipped the ground lift switch in back and it went away. I have noticed the power supply in the ART can get audible when hot, I wonder if moving it will help....
    http://www.sdiver.org
