Sub hookup
Discussion in 'Archived Threads 2001-2004' started by KevinVM, Nov 26, 2002.
  1. KevinVM
    KevinVM Agent
    May 11, 2002
    25
    Hi,
    I have a Mirage BP-150 powered sub and have a question regarding hookup. The sub has a low level L&R IN and low level L&R OUT. I am hooking this up to a Denon 3802. Do I bring the low level from the 3802 to either L or R IN and turn up the Crossover to maximum? Thanks for any input.
    Kevin
  2. Carl Mulder
    Carl Mulder Stunt Coordinator
    Nov 25, 2002
    52
    The low level your using should be mono, so it shouldn't matter on which input you use.
    One input on your sub should be mono I think but just test each input just in case.
    I have a great subwoofer so I put all my speakers on small and low bass travels primarly to the sub. The crossover is up to you but I advise a crossover of 100hz ok.
    Hope thats helped.
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I would get a "Y" adaptor and hook up to both L & R in on the sub thereby doubling the signal level.
