Sub Front Panel Came Off (1 Viewer)
squal16
nate
Hi,
I had the front wood panel of a Klipsch unglue and vibrate out of the casing (see picture). I can put it back in, but in use, it vibrates loudly. All the wires are still plugged in correctly.
Suggestions? I have some Gorilla glue, would using that to glue it back in work?
Robert_J
Mississippi
I'm not a fan of the expanding Gorilla Glue. If it expands too much along the sides, it may bow them out.
I suggest laying the box on it's back. Have someone hold the front panel high enough so that you can apply a liberal amount of Tightbond II glue to all 4 sides. Push the front baffle back into the box until it touches the stops. If you have clamps, clamp the sides. Wait 24 hours and the baffle will never fall out.
andriesprice
