GregBe
- Jul 9, 2003
My room is 19' x 19' x 8. From what I have read, square rooms are horrible as far a sub frequency response. I started with the sub in one of the front corners and had huge dips and peaks. After moving the sub around, I found a spot near my seating position that is pretty smooth and sounds great.
There are still seveal peaks and dips, but they are much tamer now. When I run a low frequency sweep, the difference between the highest peak and the lowest null is about 5db. Is this pretty normal, or is this still way too much.
I know with this room, I won't be able to get perfection, but wondering if this is good enough.
Greg
Greg
