Kevin C Brown
- Aug 3, 2000
Just curious if anyone out there has had experience with at least the Rane.
The Behringer has this annoying "feature" of testing your subwoofer's output level everytime the EQ is turned on while the sub is already powered.
(Basically, you get an unpleasant "thump" through the sub if you turn on the sub 1st, then the BFD.)
Just curious if the Rane does this.
And then, anyone with experience with both? Any comments in terms of pluses and minuses for each?
For example, BFD has 12 filters per channel, 2 channels, Rane only has 5 filters (right?); ease of use, sound quality (?), build quality, likeable factor, etc...
I have a BFD, and kind of really like it (except for the stupid freaking "thump"), but upgradeitis being what it is, maybe I would like the Rane even better!
Thanks!
Thanks!
