Sub EQ For Frequency Dip Question
Discussion in 'Archived Threads 2001-2004' started by James Edward, Mar 17, 2003.
  1. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    After a few VERY helpful threads and responses, I am down to my final issue with sub calibration.
    I have quite a dip in response at 63Hz and 80Hz. After reading about 'house curves' on the HTF, I am satisfied with my response other than these two dips. When I eq those two points about 6db up, the curve seems fine.
    But I keep reading that boosting dips is not a good thing to do. Why? It seems that a 6db boost at those frequencies should not clip the equalizer signal or overdrive the woofer.
    Is there another problem that I am creating? It seems to sound awfully good with those frequencies accounted for.
    BTW, I checked out phase issues, since it was suggested that maybe that was my problem, but phase is ok.
    Info if needed- Sub is SVS 25-31PC+, and eq is ART355
  2. Mat_M
    Mat_M Stunt Coordinator
    Jan 3, 2003
    225
  3. Sonnie Parker
    Sonnie Parker Second Unit
    Dec 11, 2001
    407
    I agree, boosting only 6db at those frequencies is fine, especially if it sounds good.
