Geoff L
- Dec 9, 2000
- Geoff
My parents new home,
Well now that we got the wood shop and garage done, (speakers Receiver & Cable TV) looking to move to the outdoors.
Other post about Kmart polyfill finished this part off. This area is done...
They have a walk out main floor, to a large deck for summer grilling, relaxing, ect.
This home is under construction and they (my father and mother) wanted to have music outside. They have a small H/K two channel stereo set up in the kitchen and the front set of speaks are thier along with the reciever. The rears, speakers B are going to be conected to the outside deck! The mid bass and high end is covered allready, with a set of out door speakers that are mouted up under the Eves and angled down to the deck. Dont remember what brand they are, but down 3db at 50 hz....
I came up with the idea of mounting one of my left over sub amps 150 watts 8-ohm 200watt 4-ohm, in the wall in side the house and running the subwoofer wires up threw the wall and to the out side overhang. The roof line allows for a large overhang, which I have complete access to right now.
Here is where some suggestions are wanted. Could you guys recomend a driver that would work ~{free air preferabley}~ or closed boxed and or ported under the over hang. It would be protected from rain and direct water contact, but would be outside and see large temp changes through out the year. (Live in central Michigan) There is room for any size driver up to 15" and big volume is not a issue at all.
(They are not party people, so major boom is not a requirment.
We have also put a fold up shelf out thier for his 19" portable TV, a power and Cable TV connection, so in the summer he /they can sit out side, grill, ect and watch the game with the sound comeing threw the outdoor speakers.
Well you have the picture now, so got any Subdrivers that might work well in this type set up? I, would prefer a free-air Driver as opposed to haveing to buid any type encloser under thier. A good front to back seal and call it good. Hook it up, set the Plate Amp crossover and volume inside, and all done.
Oh, vibrations causeing ratteling of sofit is not an issue, as they are useing cedar across the over hangs.
No metal or vinal sofit to make noise.
Any suggestions?
If you need more info, please ask... Right now, I have access to everything, walls, over hang, ect, so wireing and placement are easy at this time.
Driver Budget ~ $100.00 give or take a few bucks!
He says 25.00 but I will add 75.00 to it!
He's thrifty, he says, ya right!
Geoff
Any suggestions?
Geoff
