Sub Crossover
Discussion in 'Speakers & Subwoofers' started by vitoF, Mar 30, 2006.
  1. vitoF
    vitoF Auditioning
    Mar 14, 2006
    11
    I have a Yamaha HTR 5830 receiver. The crossover on the sub output is fixed at 90Hz. I have no idea on how low my satelittes can go, there cheap, but do the job. I have a Yamaha YST SW215 subwoofer. Any suggestions on where I should set the crossover on the sub?
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    If you're using the crossover in the receiver, then set the crossover as high as possible on the sub (or bypass it if you have that option).
