Ranga
- Nov 30, 2000
After you have calibrated your sub to read 85db (using AVIA) to match the level of the other speakers, when you adjust the volume on the receiver for normal listening, isn't the sub now louder than the rest of the speakers?
Should I be calibrating at the normal listening level instead, so that the sub's volume level remains at the same level as the rest of the speakers?
